Modeling of realistic recessed lighting with free light problem.
suldikmann
It may be that your light is a point light, in which case there isn't much surface area to reflect. If you make a bulb and give it a self-illuminating material, it'll show up in the reflections. You'd need to make sure your photometric light source is either below the bulb, or excludes the bulb from shadow casting. I'm not familiar with Vray, but to reduce render times you might also want to have your self-illuminating material not cast light into the scene, but only be visible to reflections (which is an option in mental ray). Of course, you could also give your photometric light source some area (make it a sphere instead of a point) instead of making a self-illuminated bulb object, but that may also drive up render times.
Suldik
Are you putting a ies light in the set up, which in itself won't give a light either in the spot, as it generally sets slightly down from the lamp.
A sphere with vray self illuminating material on it would do it or put it in after in Photoshop.
Your doing nothing wrong, it's a learning process.
phil
