heni30 Posted November 26, 2014 Share Posted November 26, 2014 (edited) Is there any way to change the default startup settings so that when the program starts up without a file the settings can be different? I know you can use presets but can you change, for example, the min shading rate to be 8 instead of 1 all the time. Like by revising an .ini file or something Edited November 26, 2014 by heni30 Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted November 26, 2014 Share Posted November 26, 2014 Make a scene that has your render settings and possibly a camera and light combo you want, then go to my documents/3dsmaxdesign/scenes and save the file as maxstart.max. Every time you reset or make a new scene you it loads the maxstart file with the settings you saved there. Link to comment Share on other sites More sharing options...
