sergiusese Posted November 30, 2014 Share Posted November 30, 2014 Got a problem in max2014 , I created quite a few layers and now is kinda hard to work on it.The problem is that when you select some geometry , after that the ghosting from the other shapes appear and is confusing.Tried to hide the layers and put objects on same layer but naaaaa. Searched how to delete the damn layers , but no luck so far. Any tips? Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted November 30, 2014 Share Posted November 30, 2014 Ghosting as in a deleted object stays in the viewport? I get that too. Sometimes just toggling wireframe to shaded a few times works, but mostly I have to restart the scene to get rid of them. I think it's an unsupported Video Card issue. Link to comment Share on other sites More sharing options...
sergiusese Posted November 30, 2014 Author Share Posted November 30, 2014 yes the ghost from deleted objects,but that happens if i rotate around or something like that pops in and out.Figured out how to delete damn layers finally, maybe that will help also , ill try to keep them low.Will see if i have some luck also as you said, thx. Link to comment Share on other sites More sharing options...
sergiusese Posted December 1, 2014 Author Share Posted December 1, 2014 (edited) 1 more question , cause im getting stuck. Whats the best flow from MAX to anything else.Did the 3d modelling of shape building in max and need to export it , for 2d plans(floors, partitions).Should i go Autocad? I tried like hell to see if i can handle between max and revit , but no big succes, revit wants nurbs, not triangles etc like in max export, which is so damn annoying.I know RHino and Revit works best , but aint got time to do learn and do everything back in Rhino. Edited December 1, 2014 by sergiusese Link to comment Share on other sites More sharing options...
