komyali Posted December 2, 2014 Share Posted December 2, 2014 I have presentation, 15 small videos 1 minute long. I dont want to merge them in one big video because then I would need to pres pause when I need to finish my sentence, or speek faster. If I leave separated files it will be much better for me to control presentation flow, but the question is what program to use so on my one mouse klick space or arrow it start new video file? Is it possible with After effects and does somebody have tutorial for that, also what would be good to insert loop gif file between animations. Power point sometimes have problems with videos. Any solutions or experiences with this? Link to comment Share on other sites More sharing options...
Amen Posted December 2, 2014 Share Posted December 2, 2014 I would use the pdf format for your presentation. You can even layout everything in InDesign. Use the Adobe Media encoder to transcode your video files if InDesign does not recognize your video format. In Indesign Export for PDF (Interactive). Under window>interactive>media you can change how your movies start. I hope this helps. Link to comment Share on other sites More sharing options...
komyali Posted December 2, 2014 Author Share Posted December 2, 2014 WHAT PDF? man I hate pdf, didnt know you can watch video in pdf, let me try I will inform you in couple days, tnx Link to comment Share on other sites More sharing options...
komyali Posted December 3, 2014 Author Share Posted December 3, 2014 Ok I just tried with in design and pdf, it works better than power point that stops every second. My problem is I have no clue with In Design... Can you help me, I have 15 videos 1 minute long, and looped gifs between, how to layout everything in in design? Link to comment Share on other sites More sharing options...
Amen Posted December 3, 2014 Share Posted December 3, 2014 You can use the Place command or just drag and drop objects. Those Objects are usually in a kind of a container. The outer container works like a mask but for movie clips you would just treat both as one object. InDesign is really easy to use. With a tutorial you can get the hang of it in a day. Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted December 3, 2014 Share Posted December 3, 2014 I seem to remember having to process the videos through flash first and then exporting the InDesign file as an interactive PDF. This allows you to have a PDF of each video on a new page and even choose your own thumbnail. Link to comment Share on other sites More sharing options...
Amen Posted December 3, 2014 Share Posted December 3, 2014 The Adobe Media encoder to transcode to .flv or anything else, that indesign can read. Also in InDesign you can add a different thumbnail other than just a frame from the movie. Link to comment Share on other sites More sharing options...
notamondayfan Posted December 3, 2014 Share Posted December 3, 2014 To make things really simple, what you could do is make each animation 5 mins long (1 min of animation, 4 mins of last frame frozen / black), and then when you're finished, press forward. Link to comment Share on other sites More sharing options...
komyali Posted December 3, 2014 Author Share Posted December 3, 2014 nice, I will try to export looped gif from quick time to looped animation, so that would be my transition, and while it is looped I can talk Too bad power point didnt support animations (quality) it have very good automatic and timed transmisions... As for In Design I found out basic just what I need? My question is pdf video inside file compressed, or is it taking video from folder like proxy? Just to know I dont want to go to presentation with small X in corner and missing files Link to comment Share on other sites More sharing options...
Amen Posted December 4, 2014 Share Posted December 4, 2014 The Pdf Presentation I did with a movie inside, the media was embedded inside the pdf. But it is better if your clips are not to big in filesize. A 200mb pdf is quite big... Link to comment Share on other sites More sharing options...
Fooch Posted December 4, 2014 Share Posted December 4, 2014 Keynote , on a mac makes life presenting media super easy Link to comment Share on other sites More sharing options...
komyali Posted December 4, 2014 Author Share Posted December 4, 2014 LOL apple products are for stupid and lazy people Link to comment Share on other sites More sharing options...
Fooch Posted December 7, 2014 Share Posted December 7, 2014 Or the people who use the right tools for the right job. Link to comment Share on other sites More sharing options...
komyali Posted December 8, 2014 Author Share Posted December 8, 2014 Or overpriced tool that you can buy 3 times cheaper with same hardware I realy dont understand why most of apple users have inferiority complex and have need to show yourself and be supperior than others? Link to comment Share on other sites More sharing options...
komyali Posted December 9, 2014 Author Share Posted December 9, 2014 The Pdf Presentation I did with a movie inside, the media was embedded inside the pdf. But it is better if your clips are not to big in filesize. A 200mb pdf is quite big... Thanks it works File is 74 mb but on maximum 190mb, when I put some other stuff inside it will be 250 mb but I think that is not big problem. Is it possible to insert some effects in pdf or in design like in power point, fade in fade out when changing slides (pages)? Link to comment Share on other sites More sharing options...
Amen Posted December 10, 2014 Share Posted December 10, 2014 I do not know. I have never used it. But would it not be to much movement anyway, if you have your movies in the pdf? Link to comment Share on other sites More sharing options...
komyali Posted December 10, 2014 Author Share Posted December 10, 2014 (edited) I will leave it like this, simple and effective. If everything goes as planned, you have beer 330 mb, on max There is option on export for page transitions, but I didnt make it Edited December 10, 2014 by komyali Link to comment Share on other sites More sharing options...
