New GPU in old node for Workstation...question...
Could be a PSU issue.
Other than that, are you sure the card is seated properly in the PCIe slot?
Have you tried more than one PCIe slot?
If yes, are both PCI-E power cables properly connected from the PSU to the card?
If it is a modular PSU, are both ends secured? Both in the PSU and card side?
Does your mobo "beep" or have a troubleshooting LED panel on? If so, the manual could say what the "beeping" or LED code pattern given is referring to something specific going wrong.
Sometimes we move around other power connectors and/or even RAM sticks get out of plumb when we "wrestle" big components in a case, so make sure everything is seated properly where it should be.
Oh, and probably not a X79 board or not a 2600K. Those don't work together :p
