shadows in interior from central light
vendelin
Hello,
I have problem with shadows in interior scene.
I put all type lights into the wood tube, but no shadows on ground, walls...
I am using Vray Rhino, psych. cam., GI, IR map -4,-1; LC 800. Shadows and light enabled.
I get shadow only with direct light, but unusable.
Any tips?
Thanks, Ondrej
First check is whether the scene is the real world scale as Vray calculations depend on that.
Second check is that if you are using a spherical light that try reducing the radius to get the sharper shadows that you are expecting from this sort of scene.
Thrid check if the shadow bias is set to some weird setting as it takes the base unit of the program and if it is set to meters the bias might be set to 0.1m which is super high so just adjust it to 0.001
