simonm Posted January 15, 2015 Share Posted January 15, 2015 Hi all I have a friend who needs a favour and wants me to provide 4 rendered images of a site complex at 4 key points. The point of this exercise is for them to visualise the project from these key points to see whether you can see the solar panels or not which are placed on the roofs. There are 22 homes in total and all will have the solar panels on the roof. Im thinking of placing the cameras at 1600mm above the street level, but in terms of the camera focal length, should i leave it at the default or any particular value? I mean, i dont want to warp the image by using a very wide angle and it needs to be represented accurately if you know what i mean. how would you tackle this? Thanks Link to comment Share on other sites More sharing options...
alexanderbong Posted January 15, 2015 Share Posted January 15, 2015 i believe technically human eye have a field of view similar to a 20mm camera, but the periphery is so blurred and warped that our perception of the view is closer to a 50mm. Link to comment Share on other sites More sharing options...
Stephen Thomas Posted January 15, 2015 Share Posted January 15, 2015 Focal length won't affect whether or not you see the solar panels. 50mm lens is standard used for situations like this where you are demonstrating a human perspective, but if you need to widen to capture the whole scene it won't be any less accurate. Link to comment Share on other sites More sharing options...
frog_a_lot Posted January 15, 2015 Share Posted January 15, 2015 While technically 50mm is the most correct I usually use around 35mm.. 50 just seems to be too 'zoomed in' Link to comment Share on other sites More sharing options...
simonm Posted January 16, 2015 Author Share Posted January 16, 2015 thanks for the resposne guys - its good to know there arent any special techniques much appreciated. Link to comment Share on other sites More sharing options...
