Amen Posted January 26, 2015 Share Posted January 26, 2015 Hi, I am trying to decide which would be better to get render elements into photoshop. Both can do 32 bit. But PSD manager costs twice as much. What are you using and recommend? Link to comment Share on other sites More sharing options...
braddewald Posted January 26, 2015 Share Posted January 26, 2015 It depends on what you're using it for. I just use ProEXR. Every time I start thinking about getting PSD Manager I look at the feature list and it's just not something I would ever use. Link to comment Share on other sites More sharing options...
notamondayfan Posted January 27, 2015 Share Posted January 27, 2015 Neither, I use After Effects for all colour corrections and adjustments, then export to Photoshop. Link to comment Share on other sites More sharing options...
Amen Posted January 27, 2015 Author Share Posted January 27, 2015 I tried ArionFX from Random Crontrol and I really like it. I guess ProExr should be enough. Link to comment Share on other sites More sharing options...
Nic H Posted January 27, 2015 Share Posted January 27, 2015 photoshop CC2014 works fine with 32 bit EXRS you can load files into stack, do your main adjustments then if you need access at some point to the tools that aren't available save as and step down to 16... iv also been using arion fx to add glare, bloom, grain, camera profiles and subtle abberation. then step down to 16 and do further adjustments it really depends how close your final render and how much post you do Link to comment Share on other sites More sharing options...
