[HELP] Vray Light Lister windows doesn't show nor float
inpow watir
I've found what causing the problem. The Vraylight lister window dialog was accidentally moved and put outside the 3D max window frame down below. And now i can not ge it back to accesible window area leaving it pretty useless. Does anyone have the trick/ tips on how to get it back into accesible max's window area? Appreciate any suggestion you might have.
It is a known problem. Luckily there are many ways of fixing it some of them are listed in this thread
http://www.polycount.com/forum/showthread.php?t=59862
there are scripts for it
http://www.scriptspot.com/3ds-max/scripts/reset-3ds-max-windows
http://www.scriptspot.com/3ds-max/scripts/give-me-back-my-dialogs
this is also talking about the same problem
http://3dsmaxfeedback.autodesk.com/forums/76763-small-feature-requests/suggestions/1066543-reset-all-windows-positions
if you you look around you'll probably find even more.
Google is your friend ;-)
