Revit > Max Hundreds of materials
jackpedleham
Hi, is there any way of stopping the ridiculous amount of materials in revit coming across to max? There are scores of identical materials coming through from architect models into our max scenes. Is anyone aware of a decent cleanup or 'merge similar materials' script or something? Its a very messy system.
I have made my own script for the same. It just picks it up as per the Autodesk material definitions that way everything that is Concrete gets one material that I have prepared. Also a good idea is to keep all the materials converted in an Array and when converting in the for loop check if material exists in Array, if it exists apply the same material if it doesn't then create it.
mat = obj.material
def = filterstring mat.definitionid "-"
if (def[1] == "Concrete") then
-- Create material here
Edited by siddharthkolte
