kelper Posted February 2, 2015 Share Posted February 2, 2015 Hi Guys: I make some renders in Vray for sketchup 2015 and I need the output lines to match the renders. I have the views but when I export from sketchup the white and black lines is not the same angle or match the render that I already have. I need to export the views in white to mount later in Photoshop. Any Idea of what I have to do from sketchup to match the views? I don't want to re-redner all again. Thank you. Any help I appreciate. Gonzalo. Link to comment Share on other sites More sharing options...
Eliot Blenkarne Posted February 8, 2015 Share Posted February 8, 2015 Are you using the "match photo" tool? If so, there are issues that have been covered at length regarding this. Short answer, it's likely you will not be able to get the perspective in your render and the sketchup model to match if you are using the match photo tool. Link to comment Share on other sites More sharing options...
SkylineArch Posted February 9, 2015 Share Posted February 9, 2015 In the Vray render options, click the button "Get view aspect" and render your Vray render to the desired width or height (crop it to the desired aspect ratio in post), then set your SketchUp view to the style you would like and go to Export 2D graphic and set the resolution the same as your Vray render. Link to comment Share on other sites More sharing options...
