Alpha channel for editing background in Rendering 32 bit .EXR vray 3ds max
torstenmiddelkoop
Hi guys,
I have some difficulty with my render in postproduction in photoshop.
I rendered an exterior with lots of trees. I use vray sun and sky. The render output is 32 bit .EXR. Now when i open the rgb color i need to get rid of the sky background. I would also like to keep the transparancy of the leaves. If i look in the channels i can see an alpha channel, but clicking on it only makes it pop up pink. The goal is to put in a background myself in postpro.
The hard way that i did in previous works is selecting the black parts of the alpha render pass and delete this part from the rgbcolor. Problem with this is that i don't have the translucency in the leaves and also white borders around the cut out rgbcolor pass.
Does any one of you know how to tackle this problem?
Hi Corey,
Yes I know that method. But you will end up with white borders around your edges. I hoped that when i import 32 bit in photoshop it would automatically delete my background. If i import it i can choose for Alpha Channel Data: "as transparency"or "as alpha channel". But neither of them give me an image without the background.
Sorry. I didn't want to assume anything. I figured that was too simple an answer.
Generally speaking, in a sky replacement, you will likely always get a small bit of fringing. This would be due to the the fact that the edges of your 3D object colors are premultiplied against the old sky color. This will leave an artifact of color and can be very annoying. Your best bet if you know you want to replace the sky is to use you sky image for reflections only and not the visible background. An alpha channel that is premultiplied against black will only filter the edges and leave you able to slip any sky behind your render without any halo effect.
I've certainly rendered against a visible sky and I do know what you are talking about, but the sky I have replaced it with is generally pretty close so the halo is not noticeable. Are you getting something more egregious than that? Like you use the Magic wand tool on it and it isn't getting a good selection?
