double Xeon X5680 with Supermicro X8DA3 x58
Hi Juraj,
Yes, 340Euro the combo ..hmm you might be right ..considerig all the drama with compatibility ..just for 15% faster rendering and the ivestment in old machine:p..
will have to find another technical dilema on which to waste my time:)
Thanks
Edited by xjapanese
Zero drama with compatibility. Any DDR3, any 24pin PSU with 2x 8-pin pcie aux connectors etc, any case that can accept E-ATX.
It is not that much different than current technologies. If you have most of those parts as spare, it is ok, if you have to gear up just for this rig, doesn't really worth it.
I would not mind having it as a rendering slave and whanot, but any 4-core 1P i5 today will leave it in the dust for modeling work & general computing / gaming. And you can probably get a used last generation i7 (not i5) and a s1150 mobo for that kind of money too.
Edited by dtolios
Most tasks outside rendering are single threaded, so the number of cores in a system doesn't help.
In a single threaded environment, a faster clocked i5 or even i3 would slightly beat the current 5960X flagship just the same.
Since in your example you are dealing with architecture that is 3-4 generations old and that also maxes out @ 3.6GHz, the difference is magnified.
Each generation adds roughly 10% of efficiency @ calculations per clock, and current CPUs turbo-boost 1-2 cores to almost 25% higher speeds.
The combined effect gives a comfortable advantage to Haswell consumer CPUs.
