paulhansen Posted February 14, 2015 Share Posted February 14, 2015 Hey everyone I'm trying to model a GoPro, but I'm running into a problem or two I don't know how to fix. I started out by making a simple box where I chamfer the edges by choosing edit poly and then chamfer. After that, I made the holes by drawing lines which I extruded and then I cut them out using ProBoolean. Now I want to make the inner edges chamfer as well. So as before, I choose edit poly, but some poly lines appear across the model. When I pick the edges I want to chamfer, the polygons are all messed up because of the lines. How can I solve this problem? //Paul Link to comment Share on other sites More sharing options...
mehdyt Posted February 14, 2015 Share Posted February 14, 2015 Avoid using ProBoolean , you can easily model the holes and Turbosmooth your object to get a clean topology. Link to comment Share on other sites More sharing options...
paulhansen Posted February 14, 2015 Author Share Posted February 14, 2015 Okay, so how do I cut out the multiple holes in my box and apply the rounded edges? When I choose Turbosmooth, it will apply it to the entire model. Link to comment Share on other sites More sharing options...
jensandersen Posted February 14, 2015 Share Posted February 14, 2015 Hi Paul Check out grant warwicks free tutorial on hard surface moddeling: It will give you a good understanding of how cutting, connecting edges and turbosmooth actually works. If you are lazy you can skip to the 14min and the 1hour 9min mark to see some tips on how to do "cut outs". Best of luck. Link to comment Share on other sites More sharing options...
paulhansen Posted February 14, 2015 Author Share Posted February 14, 2015 (Tak) Thanks Jens, I will check it out. Link to comment Share on other sites More sharing options...
jasonstewart Posted February 15, 2015 Share Posted February 15, 2015 You can do it the way you are doing it but it becomes problematic. Try selecting the top and bottom faces (the big flat ones) and then inset the edge a bit. That will allow you to use chamfer on the holes. Another option would be to extrude those edges in and then bridge them to create the edge loop around the holes that is required for it to chamfer properly. I do agree tho, it is almost simpler/easier to start over and make it a turbosmoothed mesh. Definitely a good skill to have/develop. Link to comment Share on other sites More sharing options...
