Rotate a speedometer needle
kishansingha
Hi,
I am new here and i need some help. I want to animate a speedometer needle that is tilted at an angle of 20 degree. Since the speedometer is tilted at 20 degree angle, i want the needle to rotate at the same angle i.e 20 degree. If i simply rotate the needle it rotates at 90 degree, therefore the needle does not rotate along the speedometer surface and the needle goes through the SM when rotating. So, how do i rotate it in the same plane as the SM. Also, i will use only 2 key frames
Edited by kishansingha
