Jon Berntsen Posted February 17, 2015 Share Posted February 17, 2015 Hi. I know this topic has been written about several times before, but I saw this image on evermotion http://www.evermotion.org/files/tutorials_content/uploads/nr_pushkin2_948.jpg, and I think the road looks good. What would be the best approach to get to this result? I am using max/vray but general methods might as well be the answer. Also, I wonder how other people would take on such a task like building the roads, pavements, curbings, plots. All splines? Would you attach the road with the rest, or leave it as a separate object? Maybe vraytexcomp used on top of a good asphalt material? The intersections are never all 9o degrees, so it would not be enough to solve with normal spline roads with constant. Link to comment Share on other sites More sharing options...
frog_a_lot Posted February 17, 2015 Share Posted February 17, 2015 Vray Dist tex in blend map will give you the dark/light areas around the edges of the roads. Use the kerbs as your Distance object. Link to comment Share on other sites More sharing options...
Amen Posted February 18, 2015 Share Posted February 18, 2015 I have not used it, but shouldn't Railclone work really well for this? Link to comment Share on other sites More sharing options...
Scott Dombrowski Posted February 18, 2015 Share Posted February 18, 2015 I've done a few civil projects. Railclone does work well for curbs and road stripes. You just need a spline for Railclone to use as a source. For the road geometry, if you have a completely flat site, you can generate this easily with an edge of pavement spline that I usually can grab from a site plan from the engineers. If it's not a flat site and you're really lucky, the engineers have designed it in Civil 3D which you can import with Civil View. I am usually not that lucky. In this case I draw a cross section of the road and the road centerline as spline shapes and use the sweep modifier to extrude the section along a centerline. I've had some success using the terrain compound object and 3D splines of the outline and centerlines of intersections. The Populate:Terrain plugin might work well for this too, but I haven't tried it yet. Link to comment Share on other sites More sharing options...
Chris MacDonald Posted February 19, 2015 Share Posted February 19, 2015 For stuff like this I use splines to model the road edges, then use a script such as Populate's "Terrain" to subdivide it in to manageable quads then a relax modifier to smooth it all out (only necessary if you've got complicated levels). The splines you used initially can also be used to create curbs either using a sweep, or as said before railclone for more detail. As for texturing, I'd probably go for the Vray Distance Tex in a composite map (I use this in preference to the Vray comp tex because it gives you far more options for layering) to create a blend between dirty/clean parts of the road. If this doesn't give you enough control you could always do a UV Unwrap which is very effective for adding texture detail. For plots/fences/walls I'd use railclone. Link to comment Share on other sites More sharing options...
