silversilverv Posted February 22, 2015 Share Posted February 22, 2015 I'm new to 3ds max and I feel like I'm missing something obvious. Simple materials render differently than they display in the view port. It doesn't matter what object, and I created half a dozen different materials, every time it's way off in the render. I've attached a couple images to show the difference. The box on the right has a UVW map and I can a just it as normal in the view port, but rendering produces vastly different results. I feel like there's some simple button I accidentally clicked or something. Any help or ideas is appreciated. Link to comment Share on other sites More sharing options...
blank... Posted February 22, 2015 Share Posted February 22, 2015 Under maps Coordinates rollout for source select Explicit map channel. You'll probably need to set it's size to a much smaller value. Link to comment Share on other sites More sharing options...
silversilverv Posted February 22, 2015 Author Share Posted February 22, 2015 I tried that and this is what I got. Link to comment Share on other sites More sharing options...
jasonstewart Posted February 24, 2015 Share Posted February 24, 2015 Are these procedural maps that you are using or bitmaps? Link to comment Share on other sites More sharing options...
