hoseinasadi Posted February 22, 2015 Share Posted February 22, 2015 Guys can you tell why the glass is behaving like a magnifier? Glass setting attached below. Link to comment Share on other sites More sharing options...
Chris MacDonald Posted February 23, 2015 Share Posted February 23, 2015 have you checked the normals are all facing the correct way? Link to comment Share on other sites More sharing options...
siddharthkolte Posted February 23, 2015 Share Posted February 23, 2015 (edited) Does the glass geometry have a thickness? Like is it a single sided polygon or a box geometry? You can set the refractive index to 1.01 to get almost non refractive glass effect. Also One more thing try changing the reflection to like a falloff to not be so reflective from front but reflective from side. Or to test you can just reduce the reflection color that... May be it is just reflecting the Brick texture... Edited February 23, 2015 by siddharthkolte Link to comment Share on other sites More sharing options...
Chris MacDonald Posted February 23, 2015 Share Posted February 23, 2015 You can set the refractive index to 1.01 to get almost non refractive glass effect. Also One more thing try changing the reflection to like a falloff to not be so reflective from front but reflective from side. Or to test you can just reduce the reflection color that... May be it is just reflecting the Brick texture... Whilst this stuff does work, it's more of a "work around" than fixing the actual problem. There's no reason that glass shouldn't work. Link to comment Share on other sites More sharing options...
Amen Posted February 23, 2015 Share Posted February 23, 2015 I sometimes had the problem, that the geometry was the reason for glass not working. I just rebuild the glass object and everything was fine. Link to comment Share on other sites More sharing options...
Tommy L Posted February 23, 2015 Share Posted February 23, 2015 Delete the smoothing groups. Link to comment Share on other sites More sharing options...
hoseinasadi Posted February 24, 2015 Author Share Posted February 24, 2015 Thanks everyone for the tips. Turned out to be the Geometry problem, initially I used a chamferbox which probably cause the problem. Cheers! Link to comment Share on other sites More sharing options...
