swimming pool caustic settings
linopoetti
Caustics for swimming pool:
Hi everyone my first post after my introduction.
Problem:
I created a scene with 3dsmax2014 and vray 3.0 which has a detached house on a site with a external swimming pool. My problem is getting caustics to the pool correctly. If I describe what I have tried below then you cans see what I have or haven’t done. I have tried to follow some tutorials on the internet with these results.
pool:
Geometry: 2500.0mmx1100.0mm plane 25x80segs
Water mat created from VRayMtl
Reflection glos 1.0, subdivs 20, Fresnel reflection ticked, ior 1.33, max depth 5
Refractions glos 1.0, subdivs 8, (use interpolation and affect shadows not ticked)
Bump in map 2.0, map type noise set to regular.
Vray settings:
Vray GI render setup brute force, Caustics ticked
Vray GI caustics, Search dis 50.0, Max photons 60, Multiplier 5.0
Lights:
Vray sun only, no daylight system: Site dimensions 61000.0x65000.0mm=61x65meters,
Photon emit radius 60000.0mm (system unit settings milimeters)
Vray light properties: Gen caustics ticked, Caustic subdivs 1500, Multiplier 1.0, Gen diff ticked
(When rendered no visible caustics)
Other attempts:
I have tried adding a direct light for just the pool using the include exclude variables-
Vray sun: Turn off vray sun caustics in light settings, exclude the pool water in the light calculations.
Direct light: exclude all accept for pool water.
Also the sun does not penetrate the water if the effect shadows variable is unchecked anyway.
I have tried many ways but with no caustics visible and have run out of ideas, my guess is that it must be something to do with the caustic settings themselves that I do not quite understand even with the vray help file and the tutorials.
Please can someone advise me please
lino
I think the caustic generator is just to get the map you can see there. Basically just a seamless water map (like the blue one you can see in the making of article.) So see if you can find a similar texture and put it into a light - it will project the image onto whatever geometry it illuminates, and thus fake the whole caustic thing.
Thank you Nicolai, but what I really need to know is what are the correct caustic settings for my model:-
Vray GI render setup Caustics:
Lights:
If these settings are set correctly then the caustics should work, I think mine are wrong and need correcting.
Can you check them out to see where the errors are please?
I have run through the tutorial fine but when I render it Is all spots over the caustic areas.
I need some help with the Vray light property settings and the render setup GI caustics settings.
please advise me what they should be?
