Bwana Kahawa Posted March 3, 2015 Share Posted March 3, 2015 Hi, I'm having real trouble aligning a model with a site photo from an iPhone 6. The way I've always aligned cameras may not be the best, but seems to have worked for me for a good few years: 1) Open the photo in Photoshop and extract the original camera make, image size and focal length (in mm) 2) Look up the camera's sensor size in mm online 3) Plug the sensor width and height and the image focal length into an old little Mac app called FOV Calculator. 4) This gives me a field of view equivalent to 35mm film 5) Plug the FOV in degrees into my virtual camera, match the image aspect ratio, and then line the model up with the underlayed photo. However, I've tried this process for 2 photos taken on an iPhone 6, and the FOV calc seems to be around 20 degrees out on both. I've double checked my process several times for both photos, but still massively incorrect. I've no idea where the error is, so if anyone could shed any light, it'd be much appreciated! Or is there a much better / foolproof method that I could use instead? Thanks, Derek Link to comment Share on other sites More sharing options...
Tommy L Posted March 3, 2015 Share Posted March 3, 2015 For cam match to an iPhone you're better ff just eyeballing it. The cam match tool in Max is pretty bad anyway. Link to comment Share on other sites More sharing options...
Bwana Kahawa Posted March 4, 2015 Author Share Posted March 4, 2015 Thanks Tom. Any idea why it's doing it? It's almost like I can't trust the metadata in an iPhone JPG. I'm aligning it in ArchiCAD rather than Max - even less accurate than Max, I suspect... Anyone else have any tips? When we're doing stuff for conversations with planning authorities, it'd be nice to be vaguely confident of our building size in the image! Link to comment Share on other sites More sharing options...
Zdravko Barisic Posted March 4, 2015 Share Posted March 4, 2015 Try this http://andklv.narod.ru/maxscripts/ak-maxscripts.html 111_cameraMatch_v0.4 Also tutorials https://www.youtube.com/results?search_query=111_cameraMatch_v0.4+ Cheers! Link to comment Share on other sites More sharing options...
Mario De Achadinha Posted March 4, 2015 Share Posted March 4, 2015 Not sure if helps but what about the new perspective match tool in 3dmax, we have had good results? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Bwana Kahawa Posted March 5, 2015 Author Share Posted March 5, 2015 Thanks guys, but again, we're using ArchiCAD, not 3DS Max. I would've assumed the maths to calculate the FOV would be the same, regardless of the intended rendering software. Zdravko, I'll check out that Youtube link. Anyone aware of any online calculators / translators? Link to comment Share on other sites More sharing options...
frog_a_lot Posted March 5, 2015 Share Posted March 5, 2015 In 3DS i usually just use vray camera.. look up the sensor size and lens size to get my 35mm equivalent.. google tells me iPhone 6 is 29mm. Punch 29mm into Vray camera, position in scene basically where person was standing, and fine tune from there.. making sure rendering output is same aspecta/resolution as original photo. Never had a problem yet. As long as the photographer hasn't used a silly mode like panorama or whatever Link to comment Share on other sites More sharing options...
