New Workstation Specs
Hi everyone.
I am trying to build a new workstation.
I typically use AutoCAD, Photoshop, Revit, 3DS Max with vray.
Intel Core i7-5820K Haswell-E 6-Core 3.3GHz LGA 2011-v3 140W
PNY Quadro K620 VCQK620-PB 2GB 128-bit
ASUS X99-A LGA 2011-v3 Intel X99 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
(2) Seagate Barracuda STBD2000101 2TB 7200 RPM SATA 6.0Gb/s
32GB RAM
Fractal Design Define R5 FD-CA-DEF-R5-BK-W Black Computer Case
Do I need to a cooler with this spec?
As you have not said anything about OC the cpu any decent cooler should like a Noctua NH-U12S but seriously running that cpu on stock any decent CPU cooler will do just see whats on special and check out a review. I would trust any of the following brands Noctua, Be Quiet! ,Corsair, Prolimatech.
GPU - GTX 970 seems to be the common card people go for due to cost and performance...... just check out some other threads I think u will find it suits your needs.
PSU - Like the cooler just get a decent brand and you will be fine - Corsair, Seasonic Enermax, EVGA even Coolmaster
If you want an amazing deal i'm sure in amongst the rough there is a diamond but its far easier to stay with known.
I would get a 700W psu although i'm sure a 600W psu or even less would be able to power your system.
My budget is around $2000 and I have a 500GB SSD for the boot drive. Any suggestions for cooler, power supply unit and graphic card?
PCPartPicker part list / Price breakdown by merchant
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor ($369.88 @ OutletPC)
CPU Cooler: Noctua NH-U14S 55.0 CFM CPU Cooler ($68.98 @ OutletPC)
Motherboard: Asus X99-A ATX LGA2011-3 Motherboard ($236.98 @ Newegg)
Memory: Corsair Vengeance LPX 32GB (4 x 8GB) DDR4-2400 Memory ($402.98 @ Newegg)
Storage: Western Digital BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive ($124.89 @ OutletPC)
Video Card: MSI GeForce GTX 970 4GB Video Card ($329.98 @ NCIX US)
Case: Fractal Design Define R5 (Black) ATX Mid Tower Case ($109.99 @ Amazon)
Power Supply: Cooler Master VSM 750W 80+ Gold Certified Semi-Modular ATX Power Supply ($100.98 @ Newegg)
Total: $1869.55
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2015-03-10 05:05 EDT-0400
The Noctua NH-U14S is a top air cooler, and should be sufficient for stock speeds and even a mild oc (4.2-4.3 maybe) with low noise levels. An equal alternative is the Be Quiet! Dark Rock Pro 3.
If you intend to try a higher oc, then go for a top AIO cooler. Your budget is high enough to fit one inside. I recommend a NZXT X61 Kraken. I have it in my system and I am very pleased with its performance and noise levels. Of course, The R5 would become a less quiet case with an AIO solution, but that's the cost for oc.
  • 1 month later...
Ok guys, I really need some advice here. I work as a 3d Visualizer and well they got me working on really huge projects that result in my file no smaller than 1.6gb. Now I thought what I was using was a solid workstation:
Specs are as follows: Windows 8.1 pro
Intel® Core™ i7-3770 CPU @ 3.40GHz 3.90 GHz
16GB RAM installed
NVIDIA Quadro 2000D 1 GB
Gigabyte Motherboard,
Can anybody kinda help me get this PC put on overdrive because my render times have more than tripled, +/- 8hr render times now. So can I get a super spec machine advise from anybody here.
Thanks in advance
