ameenharfoush Posted March 9, 2015 Share Posted March 9, 2015 Hey peeps, That's my first post here. Here's the issue i'm facing right now. I have 3 pcs here and i have 530 frames to render. The scene has static objects in an interior industrial room with moving camera. And it has 2 objects moving. So i worked on 1 pc finalized everything. Did an irradiance map with LC for 1 frame with camera path checked in both ( vray 3.0 option). The objects that are moving will not use the map but will use brute force instead. I archived the files along with the GI map and opened them in the other 2 pcs. loaded the map and rendered. The renders in both pcs are consistent but the main pc is rendering with different lighting. some of the walls were brighter etc. There's no flicker in all the renders but it's like the GI is different but it's not. Hope my explanation was enough. Anyone had this experience before? Thanks! Link to comment Share on other sites More sharing options...
shawnlim Posted March 10, 2015 Share Posted March 10, 2015 Do you change your LC to Fly through? Link to comment Share on other sites More sharing options...
shawnlim Posted March 10, 2015 Share Posted March 10, 2015 I mean when you bake file you need ti change LC mode single frame to Fly through. Link to comment Share on other sites More sharing options...
ameenharfoush Posted March 10, 2015 Author Share Posted March 10, 2015 I mean when you bake file you need ti change LC mode single frame to Fly through. Yes! Did that. maybe I found the problem.. I unzipped the archived file and opened the max scene from there and not the original one. its rendering fine now. weird since the archive has the same files of the orgiinal max file. Link to comment Share on other sites More sharing options...
