Video Maping and rendering resolution
Hello,
I have a client who is asking me to render stills at 14,000 x 8,000 pixels. this seems ludicrous to me and I tried to explain to him that he's fine using 3840 x 2160 renderings. he tells me that this is to be used for video mapping which I know nothing about. Has anyone rendered for video mapping and care to enlighten me on the subject?
Thanks!
Edited by carlangas
Probably video projection mapping. Depending on the quality of the projector they are using, you may need to render higher res than 3840 x 2160. The highest res Ive heard of for this type of application is 6k, which was projected onto a hockey rink for AR VFX.
Ask him what hardware he uses, then find the spec from the manufacturer.
I did some corporate renders last year using Dataton's Watchout for projection on a 22 x 5.5 meters complex multi-screens display ( Live feed , 3D animations & stills ) and was fine at 2880 x 786 , even used 786 x 256 still renders for a 15.48 x 5.23 meters LED screen.
As pointed by Tom check the hardware/software (how many projectors ?) that will be used for projection and the real world dimensions of the display .
Most of the time customers have no clue about the required resolution and will just ask for the maximum .
For my first mapping I was requested by the projection contractor himself to work at 7560 x 2520 ! ( ended at 2520 x 840 after a quick read through the Watchout manual :) )
14,000 x 8,000 is insane imho , have a look at some huge video mappings and their respective resolutions :
http://www.bordos.eu/applied.htm
