akbargherbal Posted March 18, 2015 Share Posted March 18, 2015 Hello everyone.. Is there anywhere an application similar to the RAM player in 3DS MAX? That one which compares between two renders? I've done a Google search and I can't find any, it seems to me a very good application that someone should have come up with already....I thought one can do it using Photoshop using a vector mask may be..... But I don't want to open Photoshop every time I want to compare two renders.... I am not sure I can use 3ds max to load not saved renderes in the history. Any help please? Thanks a lot. Akbar. Link to comment Share on other sites More sharing options...
Stephen Thomas Posted March 18, 2015 Share Posted March 18, 2015 If you use Vray you can use PDPlayer which comes with the software. Link to comment Share on other sites More sharing options...
akbargherbal Posted March 18, 2015 Author Share Posted March 18, 2015 stef.thomas said: If you use Vray you can use PDPlayer which comes with the software. I really did not know about that..... Thank you very much, you've been very helpful. Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted March 19, 2015 Share Posted March 19, 2015 I use ThumbsPlus as a thumbnailer and will open two images from there and just use tab to blink test between the two. Not quite the same as the sliding curtain, but ... enh. Link to comment Share on other sites More sharing options...
martinhoura Posted March 19, 2015 Share Posted March 19, 2015 or djv (which is free) and it's a bit less annoying to use than pdplayer http://djv.sourceforge.net/ Link to comment Share on other sites More sharing options...
