Devin Johnston Posted March 27, 2015 Share Posted March 27, 2015 Does anyone know if the VFB in version 2.4 has a problem saving out the image with color level and color curve corrections? I'm using Deadline to render out my images, it seems like there being saved without applying the color curve and levels. If I render the image directly from my machine it works fine but if I network render the images it looks like the levels aren't applied. Is this a known problem, is there a solution? Link to comment Share on other sites More sharing options...
RyderSK Posted March 28, 2015 Share Posted March 28, 2015 It's been long since I used 2.4 so I can't 100perc. confirm if there could be other case...but: To save VFB's color correction, you need to save your file under Vray/Frame buffer tab, not the general tab. Are you doing this already ? Link to comment Share on other sites More sharing options...
