joshuahovey Posted March 28, 2015 Share Posted March 28, 2015 Hi, I'm trying to create a realistic standing seam zinc material. The base metal texture seems to be working ok for me so far, but i'm struggling to give it depth - for instance the warping/ distortion you see in the lower half of this photograph on the cladding. How would I create that distortion in a vray material in 3DS? Thanks. Link to comment Share on other sites More sharing options...
justinallbee Posted May 21, 2015 Share Posted May 21, 2015 Joshua, I would do this type of thing in post production. Are you a photoshop wizard? If not you could send me a link to your final render and I can show you what I would do. Link to comment Share on other sites More sharing options...
jasonstewart Posted May 21, 2015 Share Posted May 21, 2015 You can use a noise map in the bump to get the oil canning and you could use a gradient multiplied over the top to stop it from happening at the top if you want to. Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted May 22, 2015 Share Posted May 22, 2015 Like Jason said; noise in the bump slot with a low value seems like the obvious way to go. However, depending on your client, they might not like it and would want it to appear "perfect". Link to comment Share on other sites More sharing options...
Chris MacDonald Posted May 22, 2015 Share Posted May 22, 2015 That is an absolute doddle. Noise procedural in the bump map slot. Done. Link to comment Share on other sites More sharing options...
fredriksimu Posted May 22, 2015 Share Posted May 22, 2015 Tweak this material and you'll be on your way http://www.vray-materials.de/all_materials.php?mat=2008 Also check out Peter Guthries excellent stuff http://www.peterguthrie.net/blog/2010/05/allandale-exteriors Link to comment Share on other sites More sharing options...
