xjapanese Posted March 30, 2015 Share Posted March 30, 2015 Hi Guys, I would really appreciate if someone with a Quadro 4000 and higher ( gb ) cards does a simple test.I am not sure if Shell function in 3ds max has to do entirely with the graphic card performance still results might show that . The test : 10m x 10m plane devided in 200 x 200 length segments. Perform and Inset to each polygon ( 0,3sm and delete the polygons). No put a shell function and tell what time does it take so that it it finished the shell operation. I am furstrated how that simple operation is almost impossible for me or takes 1min and 50 sek to be done ( with the risk of crashing the 3ds max ) .. ( radeon r9 270 OC version 2gb) Maybe that is a problem of 3ds max I welcome you thoughts on the subject THanks! Link to comment Share on other sites More sharing options...
Morne Erasmus Posted March 30, 2015 Share Posted March 30, 2015 The actual calculation operation has nothing to do with your graphics card. Displaying the geometry before and after has everything to do with the graphics card Link to comment Share on other sites More sharing options...
martinhoura Posted March 30, 2015 Share Posted March 30, 2015 yeah shell modifier will be cpu single threaded computation Link to comment Share on other sites More sharing options...
xjapanese Posted March 31, 2015 Author Share Posted March 31, 2015 ok I see so how is that simple computation takes so long ( 1230v3 xeon) ..doesn't seem like that task requires a cpu for 2 min.. Link to comment Share on other sites More sharing options...
martinhoura Posted March 31, 2015 Share Posted March 31, 2015 because that modifier is probably 10 years old Link to comment Share on other sites More sharing options...
xjapanese Posted March 31, 2015 Author Share Posted March 31, 2015 yes ..like the weld modifier maybe .. very dissapointing Link to comment Share on other sites More sharing options...
