Real light calculations with 3ds max and vray
smaximo
Hi there,
I just want to ask if it is possible and easy to control, illumination calculations done with vray. I was looking for something that could calculate real values of "LUX" or other type of values used by lightning designers?
Thanks
What do you want to achieve?
Do you want to measure the LUX levels in your scene or add lights of a certain lux level?
Most lighting manufacterers have IES files of their lights which give you the correct levels for that particular light.
Just stick that ies file in a photometric web or if you use VRay in a VRayIES
If you use Max Design instead of Normal Max, you can do a lighting analysis to measure the levels
