trhoads Posted November 10, 2004 Share Posted November 10, 2004 A new project I am working on, has a stone veneer around the perimeter of the building. It is a fairly rectalinear stone, and the maps turn the corners well, but the corners are too sharp, and it shows up, and I can't stand it. Any ideas on how to make the corners not as sharp. I am posting a quick shot for reference. Link to comment Share on other sites More sharing options...
kicks Posted November 10, 2004 Share Posted November 10, 2004 Link to comment Share on other sites More sharing options...
trhoads Posted November 10, 2004 Author Share Posted November 10, 2004 I tried fillet and chamfer. but that still gives them very uniform corners. I really want the corner to be rough, i just dont wnat to have to model it, this building has about 20 outside corners like this. thanks for the suggestion. Link to comment Share on other sites More sharing options...
Jeff Mottle Posted November 10, 2004 Share Posted November 10, 2004 You might want to check out f-edge http://www.ddag.org/ Link to comment Share on other sites More sharing options...
trhoads Posted November 10, 2004 Author Share Posted November 10, 2004 Thanks Jeff, I should have mentioned that I model everything in AutoCAD, and File Link. f-edge does not seem to affect AutoCAD solids. But thanks for the suggestion. Link to comment Share on other sites More sharing options...
skogskalle Posted November 10, 2004 Share Posted November 10, 2004 are you using Vray or Mental Ray? If so try the displacement map. Havent tried it myself, but that should work... Link to comment Share on other sites More sharing options...
trhoads Posted November 10, 2004 Author Share Posted November 10, 2004 Nope, not that sofisticated. Just VIZ, and VIZ 3i at that. Still trying to convince the boss I need new software. Hard to do, when they like what comes out of the old program. Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted November 10, 2004 Share Posted November 10, 2004 does the free version of vray work with your version of Viz? ...and if so, does the free version of vray support displacemnet mapping? Link to comment Share on other sites More sharing options...
trhoads Posted November 10, 2004 Author Share Posted November 10, 2004 I tried to download vray free, and they did not play well together. I could not get it to work, maybe it was my error. But in the end, i gave up. i have also read around here that displacement with vray free, is not as nice as the purchased version. Link to comment Share on other sites More sharing options...
Tim Nelson Posted November 10, 2004 Share Posted November 10, 2004 I'm pretty sure Vray free does not have displacment included anyways. Link to comment Share on other sites More sharing options...
Tomas Posted November 10, 2004 Share Posted November 10, 2004 In case you want just a still image, the most easy way is a clone-stamp tool in Photoshop, or another similar piece of SW. You can make your corners looks really good and it is not so tome consuming. Tomas. Link to comment Share on other sites More sharing options...
Tomas Posted November 10, 2004 Share Posted November 10, 2004 Here is a 2 minutes work on it. Tomas. Link to comment Share on other sites More sharing options...
thieverycorp Posted November 11, 2004 Share Posted November 11, 2004 Here is a 2 minutes work on it. Tomas. wow....u done up tat one pretty neat Link to comment Share on other sites More sharing options...
trhoads Posted November 11, 2004 Author Share Posted November 11, 2004 I have decided that is my only real option fo rany corners that are close to the viewpoint. The rest will get a rounded corner, to ease the sharpness. Thanks to all who had suggestions. Link to comment Share on other sites More sharing options...
