ronniev Posted April 15, 2015 Share Posted April 15, 2015 Hi to every one, I am working on a project, each room in different files, they are not so full, not yet lights and camera placing, but from some time, the files began work bad. One thing is that when i close each of the files, appears that rolling circle and it did not close till i close it again and appears that window with free options to close. Or, other thing (problem) is with one file that not responding all the time,,and i can wait a full day long, can't work on it. I tried to run removeNotetrack script for any help, and therefore this make file not responding too. Note: i use student version 3dmax 2012. mycomputer ram is 8 gb.. I do not know if the problem cause some windows taken from 3dskay, or louvers, but i tried to remove them and the problem remains. I lose a lot of time , please help with any tips.. Thank you. Link to comment Share on other sites More sharing options...
ronniev Posted April 16, 2015 Author Share Posted April 16, 2015 I want to tell you, that i found the solution that is fantastic. I found on a forum this code that y type/paste in maxscript listener trackViewNodes[#Max_MotionClip_Manager].track = copy trackViewNodes[#Max_MotionClip_Manager].track ,make enter, then type gc() and again enter, it will delete all worms from yr maxfile, from 609mb it turned to 49 mb, therefore my ram is not eaten so much gb,. I am thankful , good luck ! Link to comment Share on other sites More sharing options...
