vray usiing lights only sun shining through 1 portal
i have a scene set up with a vray
I am using a sun and light 2 light portals . The portal on the right has the sun directly pointing through the portal allowing the sun to pass through onto the pillow. However the light portal on the left is not creating a reflection on the floor . It doesnt have the sun ray directly pointing though . what do i use to make both first and second portal show a sun light passing through
Well if you move the sun a little up you will see the other window casting light on the floor. In the first image you have the right window throwing light on the pillow while the left window barely misses the light on the floor. To check see the floor tiles the light throws light inches out of the scene... :p
Besides I think you might know this but anyways the bed-sheet is floating... You might want to adjust that before final render.
