SgWRX Posted April 17, 2015 Share Posted April 17, 2015 hello, is there a way (or a need) to reset 3ds Max Design 2014 to defaults for Final Gather etc... after removing the Render Optimizer macroscripts? it seems like everything is done via string options, but i don't know if using the R.O. changes values in any .ini files or such? thanks, Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted April 17, 2015 Share Posted April 17, 2015 Hopefully Hot chip jump in, and he can answer that question, but usually changing your render to scaline and then back to Mental Ray, will reset all the values. I don't think Render optimizer will change anything by default. But this is a guess never used that script really. Link to comment Share on other sites More sharing options...
SgWRX Posted April 18, 2015 Author Share Posted April 18, 2015 thanks. that's right, in the past switching between renderers my mentalray settings were always reset. everything else i've learned about it i think it's basically just string options that would normally go in the .mi file (forgot about that one earlier) so i think there's no need to change anything. Link to comment Share on other sites More sharing options...
