merging an object from a scene with a different unit scale system
Illya Gamza
Hello everyone,
I have a problem merging the files from a scenes with a different unit scale system. When I merge the objects (my system units are inches ) from the other scene( system units are mm)the scale of geometry is ok, but UVW mapping is not correct. I am pretty sure it is because of the uvw mapping which is in the Real world map scale. But modifier stack is collapsed and I can't fix it so quickly, at the same time there are so many objects ;(
What are you doing folks in this situation?
Try using the xform modifier. You may either apply it from the modifier list, or you can go to the "Utilities" and choose "Reset XFrom > Reset selected". At the end collapse whole stack to edit poly, that should help.
If all your materials have the UVW mapping problem then just select all of the objects that need the change and run a script like this.
sel = getCurrentSelection()
for s in sel do
if not classof s.material == MultiMaterial then
mat = s.material
if classof mat.texmap_diffuse == BitmapTexture then
if mat.texmap_diffuse.coords.realWorldScale == true then
mat.texmap_diffuse.coords.U_Tiling = mat.texmap_diffuse.coords.U_Tiling / 25.4 -- As 1 inch is 25.4 mm
mat.texmap_diffuse.coords.V_Tiling = mat.texmap_diffuse.coords.V_Tiling / 25.4 -- As 1 inch is 25.4 mm
)else if classof s.material == MultiMaterial then
submat = s.material
for m=1 to submat.materialList.count do
mat = submat.materialList[m]
I am a bit unsure if you need to divide 25.4 to the existing Tiling or multiply (if it is multiply just change "/" to "*"
Edited by siddharthkolte
