melissat Posted April 25, 2015 Share Posted April 25, 2015 Hello, Please help me, the deadline for handling these tasks are coming soon, I really need help.....please help me with the technical issue. My client uses 3d catia ( STEP or IGES and 3dxml format files), but my university has only 3ds max license. it means I have to import these files into 3ds max. Do you know how can I import these 3d catia format into the 3ds max? what plug in I can use in this case? And one more question is about embedding 3d model into the video? Do you know how can I do it? and if there is any editing video software you would recommend? Thanks a lot for your attention. looking forward for your help. Br Melissa Link to comment Share on other sites More sharing options...
RyderSK Posted April 25, 2015 Share Posted April 25, 2015 You can import CAD files (STEP/IGES/etc..) through Autodesk DirectConnect, I think it comes included in installation since 2014+ 3dsMax, but it might be available separately to earlier versions as well. I import STEP files on regular basis and it works flawlessly, they import as 'body object' with iterative visual quality. I suggest workstation with enough memory though. You can import 3D files into number of video editors that also allow compositing, easiest would be Adobe AfterEffects. Since CS5+ it allows import in factory state, but there are plugins (like Element3D from Copilot) that makes this easier. Link to comment Share on other sites More sharing options...
melissat Posted April 28, 2015 Author Share Posted April 28, 2015 Hello, thanks a lot for your reply, but there is some errors. after I import stp files to 3ds max, the duplicates happens to some or maybe all the surfaces. Do you know how can I delete it? just keep only 1 remain of each surface. or Do you know if there is any optimizer that might help to automatically search and remove duplicates. Thanks br, Melissa Link to comment Share on other sites More sharing options...
