kris Posted November 11, 2004 Share Posted November 11, 2004 I have to make terrain and I have file with 500 points in 3d space with x,y and z coordinate. How can I connect them to make terrain in Max, Rhino or Autocad. Thanks. Link to comment Share on other sites More sharing options...
bwilson Posted November 11, 2004 Share Posted November 11, 2004 do you have a topography map of the site? If so, the process will be much easier and more accurate. If not just connect the points to create the contour lines for each elevation. I use rhino to model, and my process is to seperate each section as a seperate planar surface for each elevation then drape a surface of top of your slices to create a single surface for your terrain. Topo models can be fun projects! Link to comment Share on other sites More sharing options...
kris Posted November 11, 2004 Author Share Posted November 11, 2004 I wouldnt have any problems if I had topograph map but it was even worse when I got this plan. The client gave me just 2d dwg file with 600 points and number of Z coordinate for every point. My fiend took this file and somehow maybe by magic turned that numbers and positioned every point in 3d space. Now I have cloud of points that defines terrain but I dont know how to make terrain from it. Any idea, anyone, please.. Link to comment Share on other sites More sharing options...
jackb602 Posted November 11, 2004 Share Posted November 11, 2004 FormZ has a point cloud plugin. The standard version of FormZ includes great terrain modelling tools as well. http://www.formz.com/products/plugins/Re-Engineering.html Jack Link to comment Share on other sites More sharing options...
kris Posted November 11, 2004 Author Share Posted November 11, 2004 Is there something simillar in rhino, Max 5 or autocad becouse I dont have Form Z. Link to comment Share on other sites More sharing options...
abicalho Posted November 11, 2004 Share Posted November 11, 2004 There's a sample script in MAX called "ASCII_READ" or something like that. Check the Scripts/Examples folder to see how it works. Alexander Link to comment Share on other sites More sharing options...
S Glisic Posted November 11, 2004 Share Posted November 11, 2004 Hi Kris, You may use filter command in AutoCAD. You can isolate all points with same Z value, putt on separate layer, or… Once, when you have all points with same height on individual layer, things are easier, or I believe so… Good luck. Link to comment Share on other sites More sharing options...
kris Posted November 11, 2004 Author Share Posted November 11, 2004 Its a really small terrain for 5 houses and there are around 600 points with all diferent Z value so I would have 600 layers and thats not good idea for me. I know I can conect points manually but there are so many of them, is there faster solution becouse I have 600 points on right coordinates and I need to make mesh from them. Link to comment Share on other sites More sharing options...
mwhite Posted November 12, 2004 Share Posted November 12, 2004 If you want/can post the file, I/someone can probably turn it into a mesh fairly quicly. I'll give it ago as long as its in a from (dwg perhaps) that I can read and you can take it back as a dwg. Mike White Link to comment Share on other sites More sharing options...
kris Posted November 15, 2004 Author Share Posted November 15, 2004 Thanks for help but my friend 3d guru and he solved my problem. I dot know how but he will tell me when I find some free time after this project. He did it all automatically. No manual drawing each face. Hardly wait to see. Link to comment Share on other sites More sharing options...
Tommy L Posted November 15, 2004 Share Posted November 15, 2004 hello mate, when you find out could you let me know because i have the same problem. Cheers dude. Tom. Link to comment Share on other sites More sharing options...
