PHEN 0.5 fatal error
victoraguilar
Hi everyone, can anyone tell me what this is? I opened an oldfile that I have rendered many times before. Now this happens. The only difference is that I have instaled the iToo software forrest tool. Please help.
PHEN 0.5 975MB fatal 051109: runtime exception 0xc00000005: access violation
  • 2 weeks later...
does it render fine ? PHEN errors are pretty common, if it renders OK and doesn't kill it either it's fine. Uninstalling the iToo plugin would show if it is to blame so you can also try that. You can also apply 1 basic light grey material to your whole scene. If it will be fine with grey shader only, then check your shaders (in terms of opacity, reflection and refraction values - they should not exceed the 0-100 range if PHEN is causing any trouble).
