timphilbin Posted April 29, 2015 Share Posted April 29, 2015 Hello guys Trying to load some .max blocks into sketchup and failing...can anyone help Link to comment Share on other sites More sharing options...
siddharthkolte Posted April 29, 2015 Share Posted April 29, 2015 When you export from 3dsmax to sketchup, remember to set the units in 3dsmax to either meters or inches, unitless causes scale issues. The only way I know which works for this is through exporting 3ds file, but when imported into sketchup causes triangulation of the mesh. Link to comment Share on other sites More sharing options...
Sketchrender Posted April 29, 2015 Share Posted April 29, 2015 Convert everything to editable mesh. So select layer by layer, and convert to Em. Then export as dwg. I always find that the best results. Link to comment Share on other sites More sharing options...
ionutteudean Posted April 29, 2015 Share Posted April 29, 2015 I use Simlab Translate to convert obj's exported from max to skp. Good results without any ugly/unnecessary visible edges. Link to comment Share on other sites More sharing options...
