fernandopires Posted May 1, 2015 Share Posted May 1, 2015 I wanto to buy a renderfarm the gool is to make 1 a 2 minutes of HD video, in 3dsmax+vray , in two or tree weeks , can somebody tell me the minimum of cores to do that . Thank you, Link to comment Share on other sites More sharing options...
Dimitris Tolios Posted May 1, 2015 Share Posted May 1, 2015 Depends on the rendering time for each of your frames. If the scene(s) is/are ready for production, could you give us the rendering time on a workstation with a known configuration? Once you have that, you can extrapolate that to the number of the machines/cores that would do what you want in the timeframe you need, or tweak your settings down to make the job fit in the budget you can afford. Link to comment Share on other sites More sharing options...
fernandopires Posted May 2, 2015 Author Share Posted May 2, 2015 Thank you , i have made just rigth now the test , and each frame take 60 minutes whit the 1920x1080 res. In my Workstation whit a dual XEON E5420 2.50 (8 cpus) , Quadro FX1700, 12 GB ECC 1033. The idea is to make a 1 minute o animation in 15 or 20 days . Link to comment Share on other sites More sharing options...
Dimitris Tolios Posted May 2, 2015 Share Posted May 2, 2015 (edited) Ok. So a methodology to approach this could be: 1. Your scene will be 1 minute. Assume 24 fps. So you will have a total of 1 min * (60 sec / min) * 24 fps = 1440 frames. 2. Your current rig needs 1 hour per frame, so in theory would require 1440 hours for 1440 frames. 1440 hours = 60 days, so an approach would be that you would need a total of 3 machines like yours to do it in 20 days or 4 do do it in 15 days - assuming there is no post production. Now, you have a pretty old machine. E5420 is a circa 2007 CPU, with a Cinebench R15 score of around 270. You have 2x of those, so assume total CB R15 score of 540. Modern CPUs are much faster, so if you were to buy systems based on newer architecture (and higher clock) CPUs, you could achieve much higher scores (and effective speed) than your current system, doing the same thing with less CPUs or doing it much faster with the same # of CPUs. Typical CB R15 scores: i7-5960X ~ 1340 pt i7-5820K ~ 1025 pt i7-4790K ~ 890 pt So, should it was a "linear" relationship, you could expect a single 5960X to do what you want in your time-frame, but you would be pushing it, having the same rendering power as roughly 2.5x systems like the one you have now (I think it will actually be faster than that). To make sure I would say, 2x 5960X or 3x 5820K based rigs would cut through your task. I would dare to say that you should also think retiring your current rig. Edited May 2, 2015 by dtolios Link to comment Share on other sites More sharing options...
fernandopires Posted May 2, 2015 Author Share Posted May 2, 2015 Which of toses two configurations you recommend ? 1- Xtreme3D RF2620 4x Intel Xeon 8 Six-Core E5-2620 2.0GHz, 64GB DDR3 (32GB per node), 8x240-pin DDR3 DIMM Sockets, 2x Discos SSD Intel 520 Series 180GB, 2.5” SATA 6Gb/s, 2x VGA Asus Nvidia GT620 1GB DDR3 PCI-E, CI Slots:3x PCIe 3.0x8(1 per node), PCI Slots:1xlow-profile and 2x full-height full-length), 2x COM port (1 per node) + 2x VGA (1 per node), 4x Gigabit Ethernet (2 per node) + 4x USB ports (2 per node), Caixa Rack de 19” 2U com 75cm de profundidade, 1280W Redundant Power Supplies 80Plus, 2x Ms Windows 7 Professional 64 Bits Inglês OEM, Necessita de 4 pontos de rede para a configuração total da Render Farm 2- Xtreme3D RF2650 4x Intel Xeon 8-Core E5-2650 2.0GHz, 64GB DDR3 (32GB per node), 8x 240-pin DDR3 DIMM Sockets, 2x Discos SSD Intel 520 Series 180GB, 2.5” SATA 6Gb/s, 2x VGA Asus Nvidia GT620 1GB DDR3 PCI-E, PCI Slots:3x PCIe 3.0x8(1 per node), PCI Slots:1xlow-profile and 2x full-height full length),2xCOM port (1 per node)+2x VGA (1 per node), 4x Gigabit Ethernet (2 per node) + 4x USB ports (2 per node), Caixa Rack de 19” 2U com 75cm de profundidade, 1280W Redundant Power Supplies 80Plus, 2x Ms Windows 7 Professional 64 Bits Inglês OEM, Necessita de 4 pontos de rede para a configuração total da Render Farm Link to comment Share on other sites More sharing options...
Nikolaos M Posted May 2, 2015 Share Posted May 2, 2015 dtolios said: Typical CB R15 scores: i7-5960X ~ 1340 pt i7-5820K ~ 1025 pt i7-4790K ~ 890 pt And these are CB scores at stock speeds. A 5960X @4.4 would aprox. give over 1700cb and a 5820K over 1250cb. So, with a generous oc of a 5960X he could complete the task. Link to comment Share on other sites More sharing options...
