Roodogg Posted May 5, 2015 Share Posted May 5, 2015 (edited) Hi guys - really sorry if this has been answered, but I genuinely cannot find an answer, even on the official help files. Using MAX 15 / Vray 3 I am simply wanting to render a sequence through the frame buffer. If I tell 3ds Max to render 'range - 1 - 200', using the 3ds Max frame buffer it renders all, but if using the VFB, it calcs the LC and IRR map for the first frame and then stops. _________ Nope! It doesn't even work with the MAX frame buffer now - rendering 1 of 1 every time and it's definitely set to Range ?! eh!? what do I need to do? Thnaks for helping in advance. Edited May 5, 2015 by Roodogg Link to comment Share on other sites More sharing options...
Roodogg Posted May 5, 2015 Author Share Posted May 5, 2015 (edited) Ok - it's doing it randomly - sometimes it works - sometimes not - I can only assume this is a bug. Start / end time on vray render dialog shows 0 / 0. I'm totally stuck. Edited May 5, 2015 by Roodogg Link to comment Share on other sites More sharing options...
mjklm Posted May 7, 2015 Share Posted May 7, 2015 First thing you could try is to downlaod and install latest service packs for your max. You can also try dowgrading to Max 2014 with latest SP. You can also send me your scene so i could check it, because i haven't saw that kind of behaviour yet (and i work on the render farm for quite some time now where we are dealing with many max 2015+vray animations). Link to comment Share on other sites More sharing options...
Roodogg Posted May 8, 2015 Author Share Posted May 8, 2015 Thanks for your response. I managed to get it working simply by restarting MAX. So it had to be a bug. I have all service packs installed as well. Link to comment Share on other sites More sharing options...
