jamisonlb Posted May 5, 2015 Share Posted May 5, 2015 Im needing to create some board formed concrete and having an issue with the vray displacement map rendering out the strait lines with a wiggle or jaggedness to them. Any idea how to correct this or another way to do it without modeling it. Ive attached an example image but the one i need to produce has a bit larger seams and they want them to protrude about .5 inches. Thanks Link to comment Share on other sites More sharing options...
martinhoura Posted May 6, 2015 Share Posted May 6, 2015 do you really need displacement for it? i reckon bump would be good enough also make sure that you map is hires and blur it a little Link to comment Share on other sites More sharing options...
Chris MacDonald Posted May 6, 2015 Share Posted May 6, 2015 Displacement works by subdividing the original mesh into smaller and smaller triangles, and then moving them along their normal based on the displacement map. The jagged edges you can see are the sub-triangles; you can control how visible these are/aren't by using the "edge length" setting; I wouldn't advise going below 1 pixel. Given how simple your displacement map is, I don't know why you don't just model the grooves? Link to comment Share on other sites More sharing options...
jamisonlb Posted May 6, 2015 Author Share Posted May 6, 2015 I need it to protrude at least .5 inches with close up views bump does not accomplish this. Also this is a large complicated building and has a very specific pattern of joints so modeling them around the building would take a really long time. I'll try the edge length thanks. Link to comment Share on other sites More sharing options...
jamisonlb Posted May 6, 2015 Author Share Posted May 6, 2015 thanks edge length did the trick! cheers Link to comment Share on other sites More sharing options...
