ShaunDon Posted February 20, 2004 Share Posted February 20, 2004 Hey guys -- I've got a quick question... I'm trying to simplify some RPCs into planes with a LookAt constraint to keep them facing the camera, but I can't figure out how to constrain their orientation such that they only rotate on the Z-axis. Otherwise it keeps the full face perpendicular to the camera and pulls the trees out of the ground. Anyone have any ideas? I'm in max 4.2 if it makes a difference. Thanks! Shaun Link to comment Share on other sites More sharing options...
mbr Posted February 20, 2004 Share Posted February 20, 2004 I am not 100% clear as to what you are trying to do. RPCs are made to look 'full' from all directions, not just the two planes that are represented in the viewport. This would mean that they will always look 'full', no matter what the angle. That's the advantage of RPCs. If you are trying to keep them on the ground, well, that's another issue. There are plugins that will allow you to 'drop' objects onto a surface, like trees and fences. Link to comment Share on other sites More sharing options...
ShaunDon Posted February 20, 2004 Author Share Posted February 20, 2004 Sorry about that. What I'm doing is populating the middleground of an animation with RPC trees -- outside the loop of the camera path, but ahead of the tree wall. Problem is I have over 200 of them, and it takes a while to load all the RPCs even when culled down to simple billboards. I'm trying to save time and only using full RPCs in the building's landscaping. So I've made a plane and applied an RPC texture (just a TIF I made in Photoshop from the RPC file) and I just want to constrain that plane so that it always faces the camera. I don't care that I'm only using one image for the tree because these are peripheral background fillers, no one's going to notice that they're not rotating. But the lookat constraint by default wants to make the entire face of the simplified RPC tree look at the camera, rather than just rotate it on the Z. I've only done this sort of thing in Maya while I was in school, I don't really know how to get it to work in Max. Thanks guys. Shaun Link to comment Share on other sites More sharing options...
Quique Posted February 20, 2004 Share Posted February 20, 2004 I had the same problem a while back. I made a dummy object and with expressions made the Xposition of the dummy object equal the Xposition of the camera, same for the Yposition, but left the Z value 'height' alone. Instead of having the trees (planes) look at the camera, have them look at this dummy object. Move the dummy object accordingly in height so that the trees aren't looking down or up. I hope this helps. Link to comment Share on other sites More sharing options...
ShaunDon Posted February 20, 2004 Author Share Posted February 20, 2004 Yeah! We were trying to figure out how to constrain a dummy only to the XY coordinates of the camera... that's perfect. I'll give that a shot. Thanks! Shaun Link to comment Share on other sites More sharing options...
