text & Premier
Hi,
I was wondering if anyone could advise on the best workflow for incorporating text within a Premier edit in the same way as this Virgin Atlantic video (link below). I was thinking about rendering the text directly out of the 3ds max environment, but thought I would have greater flexibility if I created it directly within the Premier edit?
https://www.youtube.com/watch?v=17gXnTkTWvU&feature=youtu.be
Thanks.
Actually that text seems to be created in after effects, or other motion graphic software.
You can export your 3d camera path to after effects and adjust your text there.
There is an autodesk link to after effects that will help you.
Also with the new cinema 4d inside after effects, you could do the same. Still you need to export your cameras from 3d max. Or track your footage if it is not 3d.
