danteprojetos Posted November 12, 2004 Share Posted November 12, 2004 Hi !!!!! I'm trying to reproduce the effect of a glass brick on a curved wall but I'm not getting the results i'm hoping for.. If anyone has any experience making this kind of material please help me!! Thanks in advance !!! Link to comment Share on other sites More sharing options...
mwhite Posted November 12, 2004 Share Posted November 12, 2004 Here is a jpg of a stack of glass blocks which I downloaded recently. Unfortunately I do not recall where I got it so I can't give credit where credit is due. I played around with it a little bit and it now tiles seamlessly both vertically and horizontally - albiet with the black object behind the wall. Hope this helps, if you don't like the black object behind the wall, you could probably use the offset function in Adobe and get 4 blocks that are very similiar in appearance and create a new tile that does not have the black object behind the wall in the center. Hope this helps, I know this is not actually 'creating' the blocks but may do for your application. Mike White Link to comment Share on other sites More sharing options...
Frosty Posted November 12, 2004 Share Posted November 12, 2004 here are some maps i made a few years ago and a sample of them used in a rendering. Link to comment Share on other sites More sharing options...
Geoff Posted November 12, 2004 Share Posted November 12, 2004 Try this http://www.chaoticdimension.com/forums/phpBB2/viewtopic.php?t=9139&highlight=block although it's Vray you could probably adapt to suit. May have to register for the forum. Geoff Link to comment Share on other sites More sharing options...
