liorsturlesi Posted May 14, 2015 Share Posted May 14, 2015 Hi guys, I'm having some weird problem with the viewport modes in 3dsmax. All my elements seem to be very organized in layers. When i turn one of the layers off, it's content is turned off but i can see still some remains of it. I can't select the layer it's basiclly is off, But ! i can see the remains of some models - all the models in that layer are copy instances. it's really disturbing working like that. Any ideas ? somebody have the same problem ? Thanks, Lior. Link to comment Share on other sites More sharing options...
Richard Devonshire Posted May 14, 2015 Share Posted May 14, 2015 It maybe Viewport clipping causing this. Link to comment Share on other sites More sharing options...
tonybishop Posted June 3, 2015 Share Posted June 3, 2015 Are you merging or are you making the models in your scene? it does not matter which one you do. make sure you have the correct layer selected if you don't then the models will be visible when you hide the layer if you have the model group together in layers and you create a model then you would need to ungroup then re-group the layer together, if you have done this and you hide your layers and the model still are visible then you've made the models in the wrong layer. you would need to delete the models and choose the correct layer and merge or re-create them back in your scene ungroup then re-group Link to comment Share on other sites More sharing options...
