Chris MacDonald Posted May 19, 2015 Share Posted May 19, 2015 The previous exposure was much better. You're trying to render inside the room, not outside. Link to comment Share on other sites More sharing options...
jonathan Evans Posted May 19, 2015 Author Share Posted May 19, 2015 (edited) yes inside the room. Im glad it better. I set up this lighting pass as never set it up before. As i think that is some good advice and can check were the noise is on the cushions the subdivs in the lights lighting pass please see attached ok made some changes by using a value of 0.005 in the dmc sampler noise threshhold it remove some of the noise on the wall .You can see if look clos between the 2 lighting pass images ok my 3rd final lighting pass as removed almost all the noise on the back wall. As i added 25 subdivs to the lights its clear. the pillows i dont think i can clear up . Mostly clear now the noisy back wall the room is alot lighter now bit to light - might turn down the shutter speed iso Thanks for everyone who replied to thispost a learnt some new techniques. Including using the render passes which has helped locate and resolve the noise issue on the walls cheers Edited May 19, 2015 by hansolohan Link to comment Share on other sites More sharing options...
