Animation setting
aouammohamed
Hi all
i'm working on interior animation, i whant to ask if i can decrease nember of images/ second from 30i/s to 24i/s after i have saved my irradiance map with incremental add and have saver the light cache too. and if24i/s is ok to have a correct animation without problem.
also can i decrease some parameter like light subs material subs ... without have to re calculate and save le irradiance map and the light cache
thank you
If your lights aren't set to store with irradiance, then my guess is that it will be fine. Also, the Irradiance map is pretty forgiving and since there is only one map (generally) you can probably get away with changing your frame rate. I would imagine that as ling as your camera position or FOV doesn't change, you won't have any issues.
Just test a few frames.
