jonathan Evans Posted May 18, 2015 Share Posted May 18, 2015 In the 3ds max default scanline render. i am able to change the background environment to a white background or any colour . How can i change the environment background of the v ray frame buffer. Link to comment Share on other sites More sharing options...
michaelholzinger Posted May 18, 2015 Share Posted May 18, 2015 under render/enviroment/ just change the enviroment color.... Link to comment Share on other sites More sharing options...
jonathan Evans Posted May 18, 2015 Author Share Posted May 18, 2015 Please see attached . I am curretly using the environment seetings. render- environment i have changed the color to white.I have v ray physical camera in the scene . The background is a grey color. Am i using the wrong environment settings Link to comment Share on other sites More sharing options...
michaelholzinger Posted May 18, 2015 Share Posted May 18, 2015 it is because of the camera exposure- you had to turn the exposure of and also untick the vignetting in the camera settings. this should solve the problem Link to comment Share on other sites More sharing options...
jonathan Evans Posted May 18, 2015 Author Share Posted May 18, 2015 thank you. Once i turnthe exposure off . Can i still add more or less light with the f number . thank you that working now with the background nice 1 Link to comment Share on other sites More sharing options...
