HDRI rotation animaton: GI settings
Tom Bussey
I have created an animation with a rotating HDRI map. The only other animated element is the camera.
Can I collect Light Cache, Irradiance map, both or neither, or Brute force/brute force likely to be the fastest way to go?
The sequence is about 1850 frames long and the camera takes a winding path, turning about 270 degrees around a housing estate and starting from an aerial view point. I'm using vray 3 / 3DS 2014.
Thanks.
  • 4 weeks later...
I used a static HDRI with a rotation for a short clip. It worked out fine for the intention. Looked like the clouds were moving slowly and the light changes were subtle. I had a direct vray light which didn't move. As long as the clip is short - few seconds - it can work.
