Strange bucket behaviour
Devin Johnston
I'm using Vray 2.4 and I'm having a problem with buckets rendering incorrectly during DR that I've never seen before. There rendering the GI incorrectly, I'm using LC and IR like I've done 1000 times before but for some reason with this project the lighting isn't matching. I probably have 50 IES lights in this scene as well as a few vray lights and some self illuminated materials. If I render the scene with my workstation only everything looks fine but if I use DR to do it I get this checkerboard look across the whole image. I should add that this problem isn't showing up in the low resolution tests only when I try and render out a high rez image. I've tried turning up the LC to see if that makes a difference but it doesn't seem to. I've increased the light samples from 8 to 64 with no change, and I've checked to make sure I wasn't running out of RAM on the slaves. Any ideas?
