Quadro fx 1100 and power?
gigl
Hi
I using
Asus A7M266-D revision 1.0, Dual 1800+ MP's
500W Power Supply
2Monitors//1820x1024 60mhz Sony sdm-hs93/and LG f700p 1280x1024 85mhz/
Windows Xp sp1
3x 40Gb HDD Maxtor
and get a new card Quadro fx 1100 /Drv version 61.77//pny recomends to do this:i change 400Wsuplly with 500W one but still have a problem with this when im starting my windows after few minutes its stops running mouse don't moving or moves very slow ///WHY?///.Please help.
Sounds like more of a driver or compatibility problem. I bought a fx 1100 and tried using it in my old machine that was a MSI k7d with a dual athlon mp, and could never get it to work right. It would always crash & lock up on me.
The only thing that sort of solved it was to switch down to 2x agp settings in bios. I built another computer a while ago and switched the 1100 into it and haven't had any problems at all. So all I know is that it can be tricky finding the problem with the card & don't give up until you find something that works.
Gigl,
I am out of ideas. In my case it was that I forgot to connect the external power cable. However, I was getting a message that said "connect power" or some othe silly thing.
I started with a big power sipply like 550 watts. I think if you have a 500 watts PS that should be enough. Tiamtron may be right, it may just matter of drivers.
Elliot
Elliot
your Opteron mobo isnt MPX chipset based. The Opteron mobos are modern and most likely have no such problems. The AMD MPX chipset had lots of issues (I'm talking about the one used by gigl), among those issues are the vid card compatibility, usb bug and probably others as well.
Itzik,
Thanks for the explanation. I thought they where similar. So an MPX is really related only to the regular AMD's.
I don't know too much about these things. However, I know this machine is the fastest I have had and also the most stable. There is a few programs that do not work on it. One of them is the Nikon Capture Software....
Thanks
ELliot
if u think the power supply is the problem, discconect all ur hdd and ur DVD/CD , remove ur lan cards or audio cards, restart and look if the problem still there. if the problem still there, isnt the power supply.. i had the same problems some days ago...
but when the video card can't run, u can't move the mouse or seen the screen...just the pc turn off cuz the Cpu had no energy..
Does the task manager at the performance tab show 10-40% usage when you are actually doing nothing? if that's the case, it happened to me a while ago, and I couldnt do anything about it until i formated and reinstalled windows.
I can only suspect that the problem was either a virus ( i couldnt find the process that was using cpu though), or a problem with the wacom tablet drivers (do u have a wacom?) or a prolblem with some usb device. Try disconnect as many usb devices you can and restart.
it sound to me like a proscesor overhead, even a bad contact. old socket proscesor use to do that, just freeze the mouse and nothing work. try removing the proscesors, use a godddd conductor material, godd fans, even a cuople of case fans more. :D
  • 4 weeks later...
u said it was a new quadro card?
if not.... it might be that the video card is overheating... Ive never seen this cause the mouse to move slow but it will certainly lock up the system and also cause reboots...
if its a used card, check for dirt on the cards heatsink and check if the fan is spinning...
sometiems even a little dirt on the heatsink will cause overheating.... had this happen too me many times with a few different cards... south korea's air is quite dirty and it seems to end up on the heatsink pretty fast....
just a thought,
l8r
krazatchu
